HAL.BFD.QualPktResFail
Description
An attempt to qualify the packet resolution for BFD has failed. The specified return code value is provided by the low level driver which has only internal significance.
Remedy
This is an unexpected internal condition needing technical assistance. Contact technical support with the following information: - output of "show tech"
Severity
Error
Message Text
Packet Resolution %pktRes% qualification failed on slot %slot%, unit %unit% return code %rv%
Message Parameters
Name Type
pktRes uInt
slot uInt
unit uInt
rv uInt
Applicable Platforms
